It is 3/8" poly armour brake line that I made from straight lengths with the holley filter using NPT fitings. I used one 12" line from the pump to the filter then cut the line from the filter to my regulator and flared the end. You would need to buy the fittings but they are easy to source. You would need to figure out what to do at the carb for your connection. The goal is to get a safe filtter and eliminate as much rubber as you can.I’ll have to tell him about those. Are they similar to the bendable brake lines? Pretty easy to install? He’s got a Holley aftermarket fuel pump on the motor already.
Holley 162-562 100 GPH HP Billet Fuel Filter
Holley's new HP Billet Fuel Filters are part of the complete HP Fuel Systems product line. HP Billet fuel filters are precision CNC machined from 6061-T6 billet aluminum for strength and durability. They feature a black bright dip anodized body and clear bright dip anodized ends for superior...
