♥ PREMIUM SOLDER SEAL RING: Tubing reduces in size, the enough solder will melt and flow through the stripped wires, ensure a long lasting connection for your application.
♥ BETTER WATERPROOF SOLUTIONS: Double wall design, Hot Melt Adhesive inside ensures wires strongly connected and prevent wires slipping from the terminal; Polyolefin outside tubing provides insulation and improves pullout strength.
♥ ABRASION RESISTANCE HEAT SHRINKABLE TUBE: Premium tube materials are specially designed to be used in harsh environments. Protect the wires and cables from abrasion, cutting, scuffing and low impact situations.
♥ EXCELLENT WIRE CONTACT - The tin barrel provides increased current flow, and ensures less voltage drop, preventing wiring failures and reducing equipment downtime.
♥ WIDE APPLICATIONS: Excellent stability, water resistance and electrical conductivity provide durable connection for motorcycle, off-road vehicles, lawn tractors, RVs, fish finder and marine application. Widely used on multiple projects of your Christmas lights, ships with high waterproof requirements motorcycle stereo, boat electronics, equipment switches.
Love 'em. I even made myself a little jig to hold the two wires steady while I solder. Before joining, I also dip the ends of each stripped piece into a little solder flux, then use my mini-heat gun to seal. I use them all the time, even for house projects like LED cabinet lighting.
1 - 2 of 2 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
