These have about every color stripe wire you should need I am not really sure what typ3 of connectors you are looking for but bullet connectors are the most common thing to use. They need to be .180 to plug into factory for wiring. I have also bough this wire and have had no problems with it in the last two years. check molex connectors as well deutsch connectors are good for firewall pass throughs if you arent using original wiring. the molded plugs that factory wiring used is not available.I bought these crimpers along with this connector kit and this wire with no problems for the last year
