Forum Discussions about this Product
1 - 2 of 2 Posts
    1. · Just some guy
      I've noted late model F150's have a ball joint on one end and a modified traditional style "straight through" threaded end on the other which should eliminate a lot of the bind of a traditional end link. Even more interesting are the 2009 ups with pivots on both ends. I don't know how long those are though.
      2005-08 style, with measurements:
      2009 up type:
    2. · Registered
      Discussion Starter · #69 · (Edited)
      2009 up type:
      Those 2009+ ones would be perfect! They do look a touch long though for our application… and that’s the biggest hurdle we have in making this an easy upgrade; the close spacing of the sway bar end to the lower control arm.
      Edit: So the link GypsyR posted showed the longer end links for the 4WD models, and the one I posted a picture of above is from a 2WD model, which is shorter. Those might actually work… gotta see if we can dig up some dimensions on that piece!
1 - 2 of 2 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
