Forum Discussions about this Product
1 - 10 of 11 Posts
    1. · Registered
      what if i get a tweezer. how easy is that to tune myself? i don't think it is going to relearn cuz i am getting black crap out of the pipes still. i would like to do it myself if at all possible.
      You will need to get a wideband O2 gauge to get the A/F right. I bought the AEM from Summit (AEM Power 30-4100 - AEM Power Digital Wideband Air/Fuel UEGO Gauge Kits - Overview - SummitRacing.com). It's $200 with the sensor (you only need ONE). You can play with the timing but you probably won't get it right on without a dyno. You'll either leave power on the table (too little) or blow it up with detonation (too much). You might be able to find a tuning book or a web post that will get you in the ballpark.
    1. · Premium Member
      "..........I'm going to try some modifications this winter to the Double pumper I found on a web site to get a little better mileage.
      well. . . . share the wealth, what web site?
      I very good investment is a wideband air/fuel ratio gauge permanently installed in an easy to see location, it's amazing to see how much leaner a carb can be safely tuned. The $200 spent will save you hours of carb (and timing) tuning.
      analog
      AEM Power 30-5130 - AEM Power Analog Wideband Air/Fuel UEGO Gauge Kits - Overview - SummitRacing.com
      or
      digital
      also having a vacuum gauge helps to inform the driver when his foot is too far into the throttle.
      Z
    2. · Registered
      analog
      or
      digital
      Z
      Yes it is amazing what can be learned with one of these devices. Innovate Motorsports has a site with a lot of in depth carb tuning info using a wideband. I've been playing around with one this summer on my 460 with a Holley 950hp. You would think that when you buy a new carb that the calibration would at least be in the ball park? Wasn't in my case and in many others.
      I bought a wideband and about 40 bucks worth of taps, drill bits and brass set screws and I'm having a ball!.
    3. · Premium Member
      is there a tutorial on how to use that gauge?
      I have good results by following these guidelines:
      idle: as lean as the engine will tolerate and still idle smoothly. In my car thats about 13.7 to 14.0 depending on the ambient air temp.
      just off idle at a steady cruising speed: low rpm and low engine output. Here is where you can run pretty lean w/o any ill effects, and get those mpg numbers up. At least 14.7 to 15.2
      increased load: like in going up a long incline at a steady speed, 13.75 to 14.25
      acceleration & wide open throttle: best horsepower is made around 13.5
      I am using this gauge: http://www.summitracing.com/parts/AVM-30-4100/
      I'm not liking the digital readout, as it doesn't really fit in with the other gauges. At some point I'm going to put in the analog version:
      http://www.summitracing.com/parts/AVM-30-5130/
      cold engine at idle:
      full acceleration:
      hope this helps,
      Z.
    1. · Premium Member
      I'm using a Holley 650 DP
      Holley 0-82651 - Holley Model 4150 HP Carburetors - Overview - SummitRacing.com
      set up for the Paxton with advice from C. Conley. The solid floats
      Holley 116-10 - Holley Carburetor Float Kits - Overview - SummitRacing.com
      are widely available (summit, etc). We started with 71 pri. / 84 sec main jets, 6.5 power valve. Mr Conley also recommends enlarging the PVCR by 0.005. I am also using a wideband A/F ratio gauge (AEM make)
      or
      to help figure out the optimal carb setting. I was chasing a too rich condition for a long time. I went down on main jet sizes, changed power valves, both up and down. After a lot of wasted effort, I finally started changing the accelerator pump cams & fixed the issue. The stock float level is way too high and also needed to be lowered. However this is a general Holley condition and not Paxton specific.
      I'm currently using 67 pri and 78 sec. main jets, 6.5 power valve & enlarged the PVCR by 0.04 to 0.044. Now using white accelerator pump cam (the pink one was stock). Another big improvement was to use a modified (marine) air diffuser on top of the carb to even out the air flow.
      5-3/4" x 1-5/8" Tall Flame Arrestor, Aluminum
      I could probably be using the bigger jets, etc if I had a different cylinder head. I'm using the stock Hi-Po cylinder heads and they don't flow as well as the modern heads do. I'd love to put on a set of AFR heads someday.
      My timing advance was reduced from 40 degrees to 33 degrees. I would love to have one of these:
      MSD Ignition 8762 - MSD Boost Timing Master Ignitions - Overview - SummitRacing.com
      so I could run more advance overall.
      This is my second Paxton on a basically stock Hi-Po 289. I have over 40,000 miles on the Paxton over a ten year period w/o any mechanical difficulties. That has to be some some of record.
      if you need more specific information feel free to send me PM.
      Z.
    1. · Registered
      A/F meter is a great investment. Most people probably leave a lot of power on the table due to over rich tunes. It's great for EFI motors too. I use an AEM 30-4100 (http://www.summitracing.com/parts/AVM-30-4100/). I also wrote some logging software for it (it's here and free if you want it: South Street Performance Products). I need to finish the tach signal input so it will graph A/F against RPM.
    1. · Premium Member
      ".......... I know how extremely important a/f tuning as well as distributer (ignition) tuning is on these non computer controlled cars is, and I don't have the time, patience, or knowledge to figure it all out.
      why not install an a/f meter in the cockpit and you will always know if the carb mixture is in the ballpark.
      analog dial: http://www.summitracing.com/parts/avm-30-5130/overview/
      digital dial: http://www.summitracing.com/parts/avm-30-4100
      I've used the digital model for years. It has saved me countless hours when troubleshooting various carb and ignition issues. I do wish I'd bought the analog version, the digital one just doesn't blend in with a '60's era instrumentation.
      Z.
    1. · Premium Member
1 - 10 of 11 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
