My $0.02...
If you're going to order stuff from Summit....
Pistons - http://www.summitracing.com/parts/uem-kb116-030
Rod Bolts - http://www.summitracing.com/parts/arp-154-6002/overview/make/ford
Rod Bearings - http://www.summitracing.com/parts/cle-cb634p10/overview/make/ford
Main Bearings - http://www.summitracing.com/parts/cle-ms590p10/overview/make/ford
Cam Bearings - http://www.summitracing.com/parts/cle-sh510s/overview/make/ford
Cam & Lifter Kit - http://www.summitracing.com/parts/hrs-cl210031-12/overview/make/ford
Rockers - http://www.summitracing.com/parts/cca-rpm1431-16/overview/make/ford
Exhaust Valves - http://www.summitracing.com/parts/man-10775-8/overview/make/ford
Intake Valves - http://www.summitracing.com/parts/man-10778-8/overview/make/ford
Rocker Arm Studs - http://www.summitracing.com/parts/cca-4504-16/overview/make/ford
Timing Set - http://www.summitracing.com/parts/clo-c-3054x/overview/make/ford
Oil Pump - http://www.summitracing.com/parts/mel-m68/overview/make/ford
Oil Pump Driveshaft - http://www.summitracing.com/parts/arp-154-7904/overview/make/ford
Pump Pick Up - http://www.summitracing.com/parts/mel-68-s/overview/make/ford
Intake Manifold - http://www.summitracing.com/parts/wnd-8020/overview/make/ford
Headers - http://www.summitracing.com/parts/jba-1650sjs/overview/make/ford
Carb - Manual Trans - http://www.summitracing.com/parts/hly-0-4777s
Carb - Auto Trans - Holley Performance Products 650 CFM Four Barrel Street Carburetor 0-80783C
Note that I did not suggest valve springs, retainers, seats, pushrods, etc., to leave these decisions up to your and your machinist. I DID choose GT40-sized valves of 1.84"/1.54", and recommend a DIY port and port match job, making sure the exhaust port in the head is approximately 1/32" smaller than the manifold/header port. You'll want to check P/V clearance as well and pay attention to the cam manufacturers indexing recommendation.
The pistons selected with a 54.5cc chamber, a .040 compressed gasket thickness and a .016 below deck piston top yield approximately a 10.4:1 CR.
Just my suggestions and I'm sure others will have ones that are equally good or better.
