set up right you shouldn't lose any power at any rpm (over 1,200-1,300) from a vintage Paxton. In only a hundred rpm or so they are making much more power than it takes to turn the pulley. At 2,000 rpm I'm producing 2 lbs. boost, at 3,000 rpm it's over 3 lbs. Jetting is not always easy and you have to be patient to get 100% of the potential."....Would be interested to hear what can be done to the 289 to get it a bit more lively. I assume heads and a cam and headers would be a start. i have done a paxson in the past and it sapped too much low end for my tastes? ........"
Otherwise, If you've decided against supercharging, for about the same amount of money, in your place I'd get a set iron heads that have bigger valves, and flow decently, like these:
World Products 053030-1 - World Products Windsor Jr Cylinder Heads - Overview - SummitRacing.com
another cam suited to your needs
a 650 Holley carb
a 2.5" free flowing exhaust system like the magnaflow stainless
that should be enough to add substantial horsepower increase over what you have now at a cost of only $1,500 for all the about items.
Z.
p.s. re my previous post; I've been ripped off on a car purchase before, so I'm not unsympathetic to what you are going thru. Just vow to learn from your experience. No one gets thru life without a few scars...
Z.
