Forum Discussions about this Product
    1. · Registered
      There are 2 variables you have to know the values of in order to understand what is happening to the battery. One is voltage and the other is amperes or current. I have a charger that will send over 15 volts at several amps into a drained battery to fast charge it then it will start reducing the amps and the voltage as the battery charge increases. This charger has a digital readout showing the current and status of the charge process. I'm only posting this to show that 15.5 volts by itself will not fry a battery. But I think you're right that 15.5 volts above .1 amps sent into a charged battery can't be good for it.
      I have a digital voltmeter that plugs into the cigarette lighter socket. On my Mustang, as well as my other cars, I always see the voltage number changing when the engine is running. I see the highest voltages after the car has been sitting for several days and just after starting the car. Even then the highest voltage I see generated by the alternators is about 14.7 volts. That value usually bounces around like 14.1, 14.4, 13.8, 14.7, 14.4, etc. while the engine is running. Soon the values settle into the 13.x range. Are you seeing these sorts of numbers from your voltage regulator when you are driving the car normally? If you're not, I'd try a new voltage regulator.
      This is the style of voltmeter that plugs into a 12v accessory socket:
      https://www.amazon.com/Zeltauto-Cigarette-Lighter-Digital-Voltmeter/dp/B00VL9JZ0K
    1. · Registered
      When you don't have a volt meter installed, these are handy to have:
      https://www.amazon.com/Zeltauto-Cig...&sr=8-2&keywords=cigarette+lighter+volt+meter
      It is a volt meter that plugs into a 12v power outlet. Last year, I had one plugged in on my '68. When I started the car, the volt reading did not increase. First thing I did was check the wires for good connections. When I got to the voltage regulator plug, unplugging it and plugging it back in fixed the issue. The reading then went to 14.1 volts with the car idling.
    1. · Registered
    2. · Registered
      Discussion Starter · #9 ·
      If you can't use a battery tender, consider buying a portable battery pack to use after the Mustang has been sitting a while. Also, if you don't have a volt meter, get one of these. They are very handy.
      https://www.amazon.com/Zeltauto-Cig...sr=8-10&keywords=cigarette+lighter+volt+meter
      No cigarette lighter!
      I have one of those pocket size battery pack but it never worked. I use it now to charge my phone.
      I just need to drive the Mustang more often:wink:
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
