749390
On my ‘65GTFB there is gouging where the brake tab rests on the caliber. The gouging looks fresh, what caused this and how can I fix it? I tried a little filing, but the gauging is deep. Unfortunately the brake pad tab does get stuck at the gauging.
thank you!
The non-technical answer is that "stuff" is moving around that shouldn't. The backing plates (known as steels) are either not fine blank
steel accurate as far as size OR the caliper dimension where the steel plates ride isn't quite factory.
The type of rotor you have tends to exacerbate disc pad movement as well, making those critical dimensions where the pads ride even
more important.
Reactions: CHOCK
Yes movement is the issue. Anti rattle clips not holding pads secure, and rotor choice. Stock non slotted will have less drag, less movement.
You've got a couple things going on there. First, your anti-rattle clips aren't keeping the pads from moving up and down. This is/has damaged the sliding surface on the caliper itself. Unfortunately, I don't think the "bean counters" ever considered placing a stainless shim between the pad and caliper wear surface to take the brunt of wear away from the caliper itself. It is THEORETICALLY possible to machine/file the surface flat and enough to fabricate shims but my feeling is it would be easier (and cheaper) to find good reman or new callipers.
