Can you guys help me remove the doubts I'm having about recommending adapter specs for a buddy's 65?
My understanding is that 01-04 (SN95) Bullitt wheels require a 1 inch adapter up front, and a half inch spacer in the rear.
That said, the powers that be at CJ ( :shrug: ) are offering a kit that specifies 1.5 inch adapters up front. I think they're wrong, but I want to check in with people that are smarter than me before making recommendations.
https://www.cjponyparts.com/wheel-adapter-kit-5-lug-1965-1970/p/WAK/?year=1969
My suggestion is to verify the wheels. Those years should have 30mm offset. Some of the other years look almost identical but have a variety of offsets.
I'm running 99-04 bullets on my 70. 1" in the front, 7/16" in the rear.
Found specs on what I'm running.
Front:
Style: Bullitt Finish: Anthracite
Size: 17x8 Centercap Size: Large (2-1/2")
Back Spacing: 5.72" (145mm) Offset: +30mm (1.18")
Bolt Pattern: 5x4.5" (5x114.3mm) Fitment: 94-09 V6, GT, Bullitt,
Mach 1, and Cobra.*
Tires are 245/45/17
Rear:
Size: 17x10.5 Centercap Size: Large (2-1/2")
Back Spacing: 6.8" (174mm) Offset: +28mm (1.10")
Bolt Pattern: 5x4.5" (5x114.3mm) Fitment: 94-04 V6, GT, Bullitt,
Mach 1, and 94-98 Cobra*
Tires are 315/35/17 Sumotomos
I am using the Vintage Venom Cobra brake kit, it uses a
1" hubcentric spacer in the front and a 7/16" in the*rear
