Hi all. I wonder if anyone can help. I have searched high and low for the answer on the web but can't find what I need so hopefully one of you knowledgeable guys can assist!
I swapped out my old Motorcraft 3 wire alternator for a 100 amp Powermaster 1 wire. Install was easy enough but if I just disregard the old harness, the car wont start (I.e. is completely dead). I have to connect a black wire (which seems to come from the wiring harness) to a yellow wire which then goes to the + side of the starter solenoid. Then the car runs fine. It does sometimes struggle under load though - I wonder if the old voltage regulator is still interfering somewhere?
Pics attached - any pointers most welcome!
The car is a '66 Fastback, stock 289 V8.
Thanks a million,
Louis
Thanks a million,
Louis
