Hey guys--
I am getting ready to install the temperature relay thingy that makes the electric fan turn on and off at certain temperatures, and I wanted some opinions on the best place to get the +12v source. I don't really want to connect straight to the battery, as that will cause the fan to run even when the car is turned off if the coolant temperature is hot enough. I thought about the right side of the solenoid as the source, but wouldn't that cause the fan to pull its juice from the battery instead of the alternator when the car was running? If that is the case, then would the best solution be to use the alternator as the source?
One more question while I'm at it, is it really necessary to have a manually operated switch for the fan in the interior of the car? I don't really want to mount another switch inside my car if I don't have to, so hopefully someone who is using and electric fan can comment on the reliability of these temperature relay units.
Thanks for any help.
Dave
Dave
Dave
Dave
