1 - 2 of 2 Posts
Need help ID'ing the correct pinion yoke for my 69 390 4 speed car. I am trying to piece together a correct third member and am not sure which is the correct pinion yoke. I got as far as 28-spline 1330, but not sure if it should be the long or short yoke? I will be using sacorrect reproduction drive shaft and believe I need the short and wide unit for the 1.125 bearing caps, but can't find info anywhere to confirm.
Thanks in advance.
Do you have a drive shaft already?
You might want to shoot this guy an email:
Denny's Driveshafts Ford 9 inch rear end pinion yokes 1310, 1330 and 1350 series
If you do have a drive shaft: Would it be possible to mock up two different length yokes (maybe out of wood?) "long" and "short" to verify the amount of slip yoke insertion in the trans? I think drive-line angle is also an issue.
Hope I didnt add to the confusion.
Joe
1 - 2 of 2 Posts
