1 - 15 of 15 Posts
My next fix or upgrade is another steering wheel and the choice is 14 or 15 inch.
My current wheel the original has a very bad Crack n the hug and I want more space to drive so new wheel time.
Oh I did buy the seat track extender for more room. Install on the way.
The 13 to me is way to small. So it's 14 or 15.
As a young kid I had a 65 chevy stepside that I had a 13 wheel on and did ok but that was the 25 year old me The 54 me not to sure about to small wheels at low speed. Lol
On a Mustang I've run everything from a 13-1/2 to a 15 and like the 14 & 15 the best, especially with manual steering. If you're tall, like me, you can also get more knee/lap room by going with a wheel with a deeper dish which not only moves the wheel up off your legs but also closer to you... I find that when you have the seat all the way back that sometimes your arms get too straight to be comfortable with the wheel so far away.
I'll pretty much echo woodchuck on this one. The 13 1/2s wheels just look too small for some reason. The 15s are nice for manual steering, but I lose the leg room. The 14 seems to be the sweet spot. And yes, the deeper the dish, for me, the better as it positions it closer to me.
A tilt column could help a lot. Nice little mod to disguise beneath a stock steering wheel.
I have a 15" steering wheel and car has manual, quick steer (16:1) box and 225 wide front tires. It is a work out when doing tight parking maneuvers. Fine when rolling along. I would not want a smaller wheel for effort reasons. However, if you have the standard 19:1 steering box, your setup would be easier with a 14" wheel than mine.
With the shallow dish of a Moto-Lita and the length of the Branda collar the wheel is a bit tight on the legs. I wish the collar was a couple inches longer, but I have gotten used to the reach.
I am about 6'-3" and 210#
if only someone would make one for a 70...
Either or. Personally I like the 15". For one I have a 16:1 box, 4° caster and 72 spindles that have slightly shorter tie rod arms. Plus I think the 15" looks better. That's just me. And I have more then a few years on you.
I'm with Rbohm except I'm 6'4".
I went with 13 1/2 and have to agree it looks a bit smal but there's enough room for my tree trunk legs under it! If I can stick to my diet maybe there's a 14" wheel in my future.
I currently have a 15" Grant walnut .Manual steering with slow:1 box and a Shelby quick steer kit 225/45/17 or 225/50/16 4ish castor
I really like to at least try a 14" wheel
I’ve run a stock size wheel with stock power steering (way too big), a wooden 13” wheel with rack and pinion, PS, and lots of caster (feels great, looks small, gets sweaty when driving in hot weather), a 13.5” with the same setup but vinyl covered and padded (best setup thus far).
My wife’s Mustang has manual steering with the stock size wheel... lots of complaining until I installed a vinyl steering wheel cover for added grip (wheel is cracked heavily). I have a nice 14” wooden wheel to get swapped in after the rack and pinion gets installed in her car.
My $0.02... ?
I have a stock wheel on the 65 V8 and am adding Borgeson PS and a Ididit tilt column.
On my 67 I6 I have a 14" wheel and am adding EAPS .
IMO for us older or taller guys you need a small wheel with some form of power assist or a larger wheel with tilt.
I put a 14" Nardi in my 69. Expensive, but very nice, I selected a different horn button.
1 - 15 of 15 Posts
