41 - 56 of 56 Posts
In my experience, the 225 front tire is a safe size to use up front. I run a pretty low stance and have no rubbing issues.
I run a 245 on a 17x8 wheel up front. Had to clearance the UCA a tad, roll the fenders and run a little camber. I'm lowered as well, no issues.
Hi, i am about to buy some 17" wheels to be able to put some good sticky rubbers on my '66 coupe.
I know this has been already discussed but whats the conclusion with 17x8 wheels in front of a 65-66?
My plan is to go with a square setup of 235-45-17 tires, wheels would be torq thrust M 17x8 with 4.5 backspace.
Can i expect that to fit if i only roll the fenders?
I am slowly building my car so i could do some non competitive hpde events next season and the big sidewall rubbers on the 15" wheels just wont do it.
Thanks!
764308
764309
exact set up you mention. I rolled the front fenders. Shelby drop and 1” lowering springs. 4.5BS no rubbing but probably with a crazy bumpwhile turning. Normal driving no
764310
Reactions: 2nd 66
1966 mustang coupe
Discussion Starter #44
Good feddback thanks!
I did not do the shelby drop yet on mine, Charles Maier suggested me that it would not be needed with 17-18" wheel setups and up.
Ill see how it goes and may reconsider it later....
1966 Mustang GT 4sp Nightmist Blue
The Arning drop is to improve handling(which is what youre after I believe) not to help wheel fitment.
Chris
1966 mustang coupe
Discussion Starter #46
I know that, but Charles Maier seems to think that theres not much to gain by doing it with some 17-18" wheels and up with good sticky tires.
sticky tires and 17"-18" ect wheels won't help the camber curve whereas the UCA drop will and then the wheel/tire combo can take better advantage
The Shelby drop is a whole other animal and has nothing to do with tires/wheels. This is something that all Mustangs should have been done from the factory. This small change makes a huge difference in handling. I highly recommend doing this no matter what you decide to do with the wheels.
Here is a nice article that explains the Shelby drop: Arning Drop
-Shannon
which wheels? those are nice. I think the grey would compliment my colors. currently on 15" cragars.
Thank you! They are American Racing VN-427. You have to custom order these as the backspacing that retailers sell are not correct for our cars.
Chris
ok. I'll look into those AR ones but it appears the drake ones I posted above are the correct backspacing as well and 1/2 the price. not always happy with drake quality but have a buddy with another set if his wheels and they seem to be reasonable quality.
Your car looks great. Are the fenders rolled (front and/or rear)?
Thanks!! I rolled the front out of precaution, not necessity. I did not touch the rears.
Chris
Reactions: gt66a
41 - 56 of 56 Posts
