Hi so i am new to all of this but my uncle gave me his old 64 mustang straight 6 and i am trying to figure out how to install the ignition coil
- i need to know where in the engine bay it goes and hot to connect it to the battery/engine
1967 GT500
you might want to repost this under the regular "vintage mustang forum" section right under the "new member" category
The coil should be located on the driver’s side of the engine block, on the other side of the fuel pump/filter from the distributor. If it’s assembled, you just follow the middle wire on the distributor cap.
Power wire to the ignition coil is RED with a GREEN tracer and connects to the ignition coil "+" post. BLACK wire from the distributor connects to the ignition coil "-" post. Coil mounts in a bracket that is attached to the engine, to the rear of the fuel pump... see pix below.
771777
771778
