1 - 13 of 13 Posts
Does anybody have a driveshaft for a 65 or 66 mustang with a 4 speed and 8 inch rear end?
Thanks,
dm289
Yep, see if you can find a 94-01 Exploder 4 door 2WD. It'll have a aluminum driveshaft the correct length, well very close anyway at 50.5". They typically seem to use a 1320 joint however mine is from a 94 V6 and it uses 1310, same as the Mustang.
What is driveshaft length of 94 v6?
Wasn’t sure if you were just referring to explorer length.
Both same length, just differ u joints.
Discussion Starter #10
Sadly, checked the inventory at all 3 Pull A Part within an hour of me and called 10 yards... plenty of 4WD Explorers.. no 2wd.... the search is on
Discussion Starter #13
Thanks Huskinhano and 2nd 66.. found one in Louisiana on Ebay.. should have it by the end of the week!!!!
1 - 13 of 13 Posts
