21 - 24 of 24 Posts
The 4 piece 289 hi po mount is the same height too. They have a through bolt so they never fail.
You got that right. Those were massively over-built. That through-bolt is 1/2" thick.
745747
The GE-T58-10 engines we had in our aircraft didn't have mounts as strong as the 1965 289 High Performance car engine.
745745
I have a set of the frame brackets in aluminum with XE ( experimental) part numbers . Helps but they are still heavy!
21 - 24 of 24 Posts
