I need to replace the idler arm on my 1965 fastback. 289 4v, manual steering, front drum brakes. I know that there is a quick steer kit from Branda that supplies a different Pitman arm. Question: do I also need a different idler arm or is it o.k. to use the standard replacement?
You can use a stock replcaement idler arm. The quick shelby quick steer isnt really worth it unless your car sees alot of track time, or high speed driving.
Yeahhhh...BUT, with manual steering, those few extra turns can really make a big difference! I'd sasy go for it!
I sure have to disagree with you. The Shelby kit increases the ratio by enough to make it worth while. It drops the number of turns lock to lock from 4 to about 3.6.
The Shelby quick steer kit comes with both a pitman arm and an idler arm.
I have to also say that I have been very happy with the Shelby Quick Steer Kit. I had that put on the same time as the Shelby Drop was done. Car handles great and looks great too. I am very glad that I did it.
Matt
