21 - 40 of 45 Posts
1965 Ford Mustang Fastback 2+2
Discussion Starter · #21 ·
reading up on some VMF posts...I think I should be alright with those above... 15x7 front and 15x8.5 rear
Doing the shelby drop.
Will have new Eaton coils (reg...not lowered) and springs.
Will have new konis or bilsteins...still making up my mind.
Tire size im leaning towards 225/60 in the front with 245/60 in the rear....
Discussion Starter · #25 ·
What year is your car?
65
got a sorta rebuild thread here
1965 Coupe C-Code
Speaking of wheel center caps this guy makes a variety of aluminum center caps for TT wheels.
He also does complete custom jobs.
He’s working on some tribar caps (not the flat caps) with painted logos.
245/60-15s work on 15x7 with 4.25” bs on the rear, fenders have to be rolled flat, suspension needs to be stiff and you need to cross your fingers a lot. But it sure does look good….
Eh, not going to mess with that then. Probably should just get 7s all around and keep with the slightly fatter tire
7" and 8.5" have the same backspacing (3.75"), which gives a nice "deep dish/wide track" look, but while the 7" (barely) fit, the 8.5" wheels are simply 1.5" too wide. All depending on the tires too, obviously.
I believe they now also make them in 8" wide, with a 4.5 backspacing. They would probably fit with respect to the fender lips, but may cause problems with the upper control arms if used on the front.
or....? Maybe these look closer
I may be repeating but the "original" wheels were TRUE magnesium and magnesium oxidizes quickly even when polished. They turn very dark grey when they oxidize. The color is almost like dark grey primer. For the record ALL of the R Models ( not just the prototypes) used the magnesium 15x7 wheel AND they were available in the Catalogs as well . The current American Racing TT"D" offering is close and many vintage racers use them instead of the ultra pricey originals. Aluminum is a FAR safer material for wheels.
0
Most racing rules require that caps , trim rings and anything else that could fall off be removed from the wheel before tech inspection.
You need 4.25 backspacing to clear stock fenders and quarters with a 15 x 7.
As far as I can tell AR does not make that size unless you special order them at a premium price.
most 15 x7 wheels come 4.25 except AR.
ken
Here‘s where I got my center caps. Very happy.
21 - 40 of 45 Posts
