1 - 16 of 16 Posts
It should also be Palomino.
If the car came from the factory with a full-length console then it most definitely would have come with woodgrain inserts. Have seen short A/C console both ways.
Oh yeah, you can buy repro wood grain. Try to find the type with the metal backing, otherwise you'll have problems with it peeling up.
It's $49.95, but it still "peels" right where the console goes from horizontal to sloping up towards the dash :confused: unless you're lucky. Check the lengths also, some are a little too long and overhang requiring trimming to size with a tin snip.
I might have a complete extra set for an a/c car. I thought I had lost the first set I bought, and then found it after I bought another (of course!).
On an a/c console there is almost no upward curve and the end cap covers the last couple of inches where it barely turns up.
And I'm pretty sure I have a full set I don't need.
Hosted on Fotki
Always considered the possibility that the ones without (very few I've seen) were those installed at dealerships or after.
I haven't ever seen a low milage unrestored 65 with Delux interior and AC that had woodgrain on the console,including the two that I have owned.My 10K vert's console was factory installed and dosn't have the woodgrain applied.
1 - 16 of 16 Posts
