1 - 2 of 2 Posts
I'm trying to put together a working 1965 OEM Rally Pac Clock, but I'm missing the small time set gear at the end of the chrome stem as well as the spring which retracts the stem back into the clock after the time is set. Does anyone know if there are any substitutes for the gear (maybe from a different clock or other device) or the spring (I tried one from a pen, but it's too thick)?
Thanks in advance, all!!!
Discussion Starter #2
The size of the gear is 0.5cm (5mm) across tooth to tooth and it has 12 teeth.
Thanks for the help!
1 - 2 of 2 Posts
