I have a pair of reproduction purchased seversal years ago. How do i tell which goes on which door? What is the channel on the bottom of the doors for?
Ok.... Truth is, they can only really go in one way...
The fatter end (should have a pilot hole in it) goes near the lock. Flat side down.
You need to use weatherstripping adhesive. It's like contact cement, it has to dry in order to get tacky and then you can install. Take your time since you really only get one chance ! :)
The weather strip gets pressed into that channel at bottom of door , hold it in place with the contact cement
