1966 GT Fastback, 289, TKO 5-spd, EFI, 4-discs, TCP coilovers
I am offering my 1966 Ford Mustang GT Fastback A-code for sale. It is a “real” GT, with the factory buck plate and all authentic accessories present, and except for the wheels and tires, the car appears completely stock. Reason for sale - imminent retirement, moving away, lack of use, evolved interests.
The car is appraising in the $60's, but I will listen to offers in the $50's. PM me if interested.
Over the last two years, I have completely gone through the whole car to clean, repair, freshen, upgrade and modernize everything. There are tons of posts about this car on VMF ("Stella" - '66 Fastback Factory GT). It is now a solid, reliable, fast and beautiful Mustang that you can just drive to a car show.
It is stock on the outside, but it is a restomod underneath. The majority of the mods are bolt on (no hacking, cutting, welding or tributing) and are reversible back to true factory, if desired.
Engine:
  • The original 289 V8 block (by date code)
  • New Edelbrock Pro-Flo4 multi-port fuel injection with aluminum intake manifold
  • New stock 16-gal gas tank with in-tank Walbro pump and two-way fuel lines
  • Edelbrock aluminum heads (resurfaced)
  • Mild Comp cam with hydraulic lifters and Crane roller rockers
  • New Ford Performance silver ceramic headers with older Flowmaster exhaust
  • New chrome oil pan, chrome water pump and starter
  • New Champion 3-row aluminum radiator and Milodon high flow thermostat (180)
  • New LoPro electric fan (2700 cfm EFI controlled) and sealed shroud
  • New CVF polished hydraulic hood hinges
  • New plug wires, battery, belts, hoses, gaskets and seals
  • Chassis dyno tested - 315 HP at 5500 rpm
Drivetrain:
  • Tremec TKO 3550 5-speed transmission (3.27 1st gear, 0.68 5th gear)
  • New Modern Driveline clutch, pressure plate and Kevlar clutch disc
  • New Modern Driveline hydraulic clutch with Tilton 6000 internal throwout bearing
  • Period-correct Ford bellhousing (replaced)
  • New roller bearing clutch and brake pedal
  • Rebuilt 8” Ford Trac-Lock differential with 3.55:1 gears and 3-inch driveshaft
Suspension:
  • Updated Total Control Products front coilovers (400 lb) with 1” drop spindle
  • New TCP Vari-Shocks (double-adjustable) front and rear
  • New Eaton Detroit rear leaf springs (110 lb)
  • Foose alloy wheels (17 x 8) front and rear
  • Hankook Ventus Evo2 tires (225 x 45) front and rear
Steering and Brakes:
  • Total Control Products power rack and pinion system
  • New Ididit tilt steering column with original stock steering wheel
  • Rebuilt SSBC 4-piston front calipers with slotted discs and 7” power boost
  • SSBC single-piston rear caliper with slotted discs and cable parking brake
  • New Leed master cylinder, booster and proportioning valve
Electrical:
  • Complete new Painless Performance 22-circuit wire harness; every wire replaced
  • New chrome alternator 130 amp
  • HID headlights and LED taillights
Interior:
  • Complete interior cleaning and restoration down to the sheet metal
  • Fresh interior paint, Dynamat heat / sound barrier and new underlayment
  • New TMI 2 vinyl upholstery, cut pile carpet, door panels and dash pad
  • Vintage Air air conditioning and heat system
  • Autometer 6-gauge instrument cluster with 3 new gauges
  • New Autometer GPS speedometer
  • New North Coast seat extender driver side
  • New door seals and sill plates
  • New window scissor crank mechanisms; both doors
  • Restored sail vents and panels
  • Custom carpeted trunk floor
  • Retro Sound AM / FM / Bluetooth sound system with hands-free phone
  • SWD backup camera in license plate (tablet or smart phone based) - very helpful
Other:
  • Paint, glass and chrome are not new but are in excellent condition
  • Licensed and insured as a Classic Car in PA and is located in Doylestown, PA
  • Complete records, including prior owner work and the original bill of sale
  • Everything on this car works
  • There is absolutely no rust on this car, and you can eat off the underside
  • No leaks, smoke or interior smell
  • All modifications have been done “reversibly” with
  • Critical work done by professional mechanics (not me)
20200223_154239_Adj.jpg 20200223_154111_Adj.jpg 20200223_154321_Adj.jpg 20200223_154137.jpg 20200223_154152.jpg 20200223_154513_Adj.jpg 20200223_154806.jpg 20200322_113832_Adj.jpg EFI Left 2.JPG Engine Bay Adj.jpg
1966 Mustang GT 4sp Nightmist Blue
GLWS!! Beautiful car.
Chris
Beautiful and well sorted car. I’ve always admired it. Sorry to see you selling, but I’m sure the next owner will enjoy the heck out of it. Good luck with the sale and your retirement.
Engine:
Drivetrain:
Suspension:
Electrical:
Interior:
Other:
View attachment 759738 View attachment 759737 View attachment 759739 View attachment 759740 View attachment 759741 View attachment 759743 View attachment 759745 View attachment 759748 View attachment 759746 View attachment 759747
Is the car still available?
Mike
210-414-9100
