1 - 2 of 2 Posts
Need some help with a Brake light problem on a 67. Power assisted Drum Brakes all round
At rest brake lights work fine A slight jab of the pedal and on they come BUT as soon as I start driving I need to jump hard on the brakes for them to work. Bloody dangerous as I can't "feather " the pedal to toggle the break lights.
Blinker lights work fine and seem do do what they should
History
I changed the original steering wheel to a Grant All seemed OK . Some months after changing Steering wheel backed car out of garage to let it run for a while as it had not seen the daylight for around 6 weeks.
Back in garage and noticed a ticking sound when car shutdown. Noticed tick coincided with interior light flickering on and off Quick disconnect of battery and found Grant horn button red hot. Revisited the insulation I had on the horn wiring and all seemed well Horn works etc. Some time later whilst on road informed I had no brake lights Tested at rest and all fine so assumed dirty switch. Problem however has continued _ Brakes test fine at rest but when travelling I have to slam them on to get the brake lights to work. I have changed the brake light switch and no change. Even added a 1/8" plate to the contact area of the switch and found at rest the brake lights stayed on so clearance or play doesn't seem to be the problem and hence removed the additional plate
Only other mod has been to add a small tacho
It's doing my head in - where do I start???
Thanks in advance
Do the brake lights work if you're idling with the car on and not moving?
Maybe it's the turning of the steering wheel that's cutting off your brake lights? Try turning the wheel while you're sitting still and see if they cut off.
Just a couple ideas to get you started.
Oh, and make sure your hazard switch is all the way in or out (whichever way it sits). That can interfere with things too sometimes.
1 - 2 of 2 Posts
