1 - 12 of 12 Posts
The car I put a deposit on back in December was, thankfully, delivered on Saturday. Overall, while there is a ton of work to do, I am pleased with it. The seller is a body man and did all of the sheetmetal work himself but ran out of time and interest. So I scooped it up knowing that the heaviest lifting has been done.
750512
Congrats! So what’s the plan?
Welcome, I’ll be following.
I’ll move this to the Build Section.
68 Mustang Coupe
following
Discussion Starter #10
The plan is to finish the body and get it covered in epoxy primer. First thing though is getting the bare metal primed. Then I am going to paint and seal the foors, top and bottom. I have a bit to do under the dash too. Then I will grind down the welds wherever necessary before setting the stall up as a spray booth. Once that is all set to go, I am going to send it out to have the roof, cowl and door jambs blasted.
Then it's primer time.
Discussion Starter #12
Quick update......
...... The weather still sucks. So not much has happened. Although I am getting the shop organized and creating room to work.
1 - 12 of 12 Posts
