No Reserve: 1967 Ford Mustang Convertible
BaT Essentials
  • Lot #36621
  • Seller: shelbyluva
  • Chassis: 7T03C113367
  • 71k Miles Indicated, TMU
  • 289ci V8
  • 3-Speed Automatic Transmission
  • Color Changed to Red over Parchment Vinyl
  • Power-Operated White Soft Top
  • Vinyl Soft Top Boot
  • PerTronix Ignition Module
  • Front Disc Brakes
  • Power Steering
  • Transmission & Carb Rebuilds in 2017
  • Build Sheet
  • Partial Service Records
  • Private Party or Dealer: Private Party
  • Model Page: Ford Mustang 1967-1968
    This 1967 Ford Mustang convertible was acquired by the seller in Ohio 18 years ago and is powered by a 289ci V8 paired with a three-speed automatic transmission. The car is finished in red with a parchment interior, and equipped with a ***********-operated soft top, a matching vinyl top boot, 14″ wheels with whitewall tires, front disc brakes, and a PerTronix ignition module. Service in 2017 is said to have included rebuilds of the brakes, transmission, and carburetor as well as fluid changes and a fuel system flush. This Mustang is offered at no reserve with three keys, partial service records, a build sheet, and a clean Ohio title in the seller’s name.
The car was repainted from Lime Gold to its present shade of red under previous ownership. The seller believes the rear quarter panels and outer wheel well liners to have been replaced, and the floors have received patched panels. Corrosion is noted on the undercarriage along with bubbling paint on the lower edge of the driver’s door.
The power-operated soft top shows scuffs and is photographed both lowered and raised. A matching top boot is included in the sale. Steel wheels with aftermarket faux wire covers wear 14″ Parkway radial whitewall tires. Front disc brakes and power steering are equipped, and the brakes were reportedly rebuilt in 2017.
The interior was retrimmed in parchment under previous ownership and features black carpets with matching Mustang-branded floor mats. Amenities include lap belts, crank windows with wing vents, and an AM radio.
A three-spoke steering wheel frames round gauges including a 120-mph speedometer as well as readouts for fuel level, oil pressure, coolant temperature, and alternator output. The five-digit odometer shows approximately 71k miles, 25k of which were added by the seller. Total mileage is unknown.
The 289ci V8 has been equipped with a PerTronix electronic ignition module and sends power to the rear wheels through a three-speed C4 automatic transmission that was rebuilt in November 2017. Additional services at the time included a carburetor overhaul as well as fluid changes, a fuel system flush, and replacement of the fuel pump, distributor cap and rotor, battery cables, and spark plugs and wires.
Additional undercarriage images can be viewed in the gallery.
The build sheet decodes as follows:
  • Body – 76A, Mustang two-door convertible
  • Color – I, Lime Gold
  • Trim – 2G, Gold Vinyl
  • Assembly Plant – T, Metuchen, New Jersey
  • Production Date – September 23, 1967
  • Engine – 289ci V8
  • Transmission – Three-speed C4 automatic
A letter from the customer service division at Ford lists factory colors and options.
Service records are included in the sale along with three keys and the factory wheel covers. A fender VIN stamp and reproduction door tag are shown in the gallery. Startup and drive-by videos are provided below.
No starting bid, and the current high bid is $13,750.
