Ok, my float came off my fuel sending unit so I took out....saw that the pieces of gasket are deteriorated and crumbled. Also the brass float is inside the new tank.
Question is: Should I worry about the loose float staying inside the tank and possibly have to pull the tank out of the car or just install a new fuel sender and call it good?
If you completely empty the tank it would be easy to get out.
If you fill the tank up, and shake it around, chances are the float will come up the filler neck.
