1967 mustang GT S code 4 speed for sale https://www.ebay.com/itm/173879268682
Vehicle Description
Genuine 390, 4-speed GT fastback that has undergone a concourse, rotisserie restoration. This car was restored by Bryan Edson at Cars Inc in Lees Summit Mo, Documented with Marti report. Original numbers matching motor, trans and rear. Car was completely original prior to restoration except for air cleaner. During restoration all original ford parts were restored and retained if possible.
EXTERIOR: It's a gorgeous car to look at. The fastback is one of the most desirable body styles of all time. We have photos of the body taken down to a bare shell on a rotisserie. It is all metal, it's straight and fits right. Doors, fenders, hood and trunk were refinished inside and out. The Acapulco Blue paint is polished like glass. Jambs are detailed. New weatherstrips and rubber seals. Exterior chrome has been refinished , polished or replaced. The windshield is new, rest of the glass is original. New Styled steel wheels with new tires. This car was ordered with the decor group, It has louvered hood, pop out gas cap and finned tailpanel. The GT package includes emblems, stripes, fog lamps and splitter exhaust tips.
INTERIOR: Inside the car is completely restored. new carpet, upholstery, headliner, door panels etc. It also has new handles, cranks, steering wheel etc. The dash area is all restored and features tachometer, clock and original radio. It also has fold down rear seat. Interior lights all work.
ENGINE COMPARTMENT: Original born with 1967 390 motor has been completely rebuilt to stock specs bored 30 over. It runs perfectly. The motor compartment is detailed out like the day it came off the assembly line. Correct Ford hoses and clamps and filters. Autolite battery topper and plug wires. Everything is painted beautifully, all smooth finishes. Original Holley carburetor with original tag ,Correct manifolds, air cleaner and valve covers. Bottom of hood is detailed in Acapulco blue and has the turn signals wired in to the louvers. Original born with RUG M2 4-speed. It has correct reverse lock out handle.
TRUNK COMPARTMENT: The inside has all clean metal painted blue. There is a brand new tire on a Styled steel rim for a spare and the correct plaid mat. Everything is detailed, the latches look new, weatherstrip and jacking instructions decal are new etc.
UNDERSIDE: Wow, it's really impressive underneath this car. It is highly detailed. We have pictures of the bottom of the car on a rotisserie. The metal looks pristine- the frame rails, seams, 4-speed hole look like factory new. Correctly sprayed in red oxide. The steering and suspension is completely rebuilt and detailed in the proper finishes. It even has assembly line paint markings applied. Bottom of motor is spotless. The original 4-speed trans was rebuilt, it has original tag with correct codes. The 3.25 limited slip rear end was rebuilt and also has original tag with correct codes. The exhaust system is a new correct reproduction with transverse muffler. All new brake system with disc up front, e-brake is functional.
816-898-7282 Contact Bryan to discuss any details on car Contact me if interested I can send you 100,s of pics website will not allow me to add all these
S code 390
GT equipment Group
4 speed
Power steering
Power disc brakes
Fog lamps
Styled steel wheels
Reproduction tires,
Exterior décor
Lower Back panel Grill
Limited slip differential
Deluxe seat belts
Tachomete
Vehicle Description
S code 390
GT equipment Group
4 speed
Power steering
Power disc brakes
Fog lamps
Styled steel wheels
Reproduction tires,
Exterior décor
Deluxe seat belts
Tachomete
Brian, please see my opinion comment on Build Forum about C.A.R.S. INC. I believe that you may be a partner in the company that can try to settle this matter. If I am wrong please disregard. Thanks.
