Thank you so much for your input. I appreciate it and make those changes. It’s always good to have a second set of eyes.Wow, that looks nice. The I think the gray distributor cap and the belts are the most obvious. But it looks great. And I'm not sure if the oil filler cap is supposed to be silver, or black. Most of the ones I've seen are painted black....not sure if black is correct though.
Thanks for your input. Ford changed to Corporate Blue in 1966.Shouldn’t it be a steel line (from carb to distributor)? With the matching vacuum actuator. To be correct that is. To get it to work a rubber hose will work fine of course.
I know that a dark Ford blue exist but was it used in 1967?
Thanks for your input. I’ll source out the proper belts and make that change. I have to get a different distributor, it misses under load with the vacuum advance hooked up.Belts,Vacuum advance hose .
I did not know that. Thank you for your input.Depending how correct you want engine bay area done, one often overlooked thing is the "body color" paint edge on fender apron at firewall.
The body color should be even with firewall, as I understood Ford masked a straight line across when painting. I've bought a few unrestored junks and been to Carlise Ford Nationals and have seen this was the way stangs were painted.
Attached a couple pics of my 67 GT 390 after I restored it to best show apron paint line.
Thanks for your input, I’ll take your advice and make those changes.Wow, that looks nice. The I think the gray distributor cap and the belts are the most obvious. But it looks great. And I'm not sure if the oil filler cap is supposed to be silver, or black. Most of the ones I've seen are painted black....not sure if black is correct though.
Thanks BryanAs mentioned, the blue is too dark on the engine. Ive messed that up in the past, and I’m just living with it on my ‘69 as it’s too much work to haul the engine back out.
On this link, you’re looking for “Old Ford Blue”. Duplicolor engine paints (click on the colors tab)
Everything looks so nice in your engine bay…so I wouldn’t change from the way it is now (paint-wise). I love 67s!
67 had a rubber hose.Shouldn’t it be a steel line (from carb to distributor)? With the matching vacuum actuator. To be correct that is. To get it to work a rubber hose will work fine of course.
ConcoursMustang.com, and Google images is your friend if you don't find it on VMF.Is there a library source of images of extremely well done engine bays out there the rest of us can use as reference?
