21 - 40 of 63 Posts
Discussion Starter #21
some prep before putting rail in place..
more parts come from sandblasting
ebay tips but too small i think
front rail in place and welded...
Discussion Starter #23
I am father for the second time. now mustang will be in future for Dorijan and David :)
And ofcourse less time for work... but i have time until they get older..
Tipical problem on stang with double sheet metal..
2mm pach and then 0.8mm on top.
welding pinholes with help of copper tube. cool results..
Discussion Starter #24
rear fender aprons came flat and no holes..
no problem for my diy press.
apron in place and welded..
left side almost done oujeaaa...
I have new front left apron but i have saved original and will be hammered/flattened just because of vin..
On last pic you can see gap between shock towers after mounting export bace..
Discussion Starter #26
There is a difference between 30$ and 50$ sheet metal
Dynacorn - 1mm metal -put on prepared car and fix with two clamps and ready to weld. --- 5min
cheap cj pony - 0.7mm metal - does not have holes for bolts
1cm to wide on shock tower side
not bent on fender side
poor fitment on cabin side --- 3hours
Next time I will know
Discussion Starter #27
aprons welded...
repair on rail..
nice picture of accomplish to me :)
floor pans soon...
one more rail repair
rail...
hole for grease fittings welded
Discussion Starter #28
reinforcement for shock tower
one more weld to be shure
welded for good
soon front end will be finished with welding
some bigger tips from ebay...
Discussion Starter #30
Not yet. I am planning to do the drop. Only problem is with upper ball joint and its angle...
trying to find solution for that first then drilling holes.
plan is drop and original old springs just for little lower than stock..
and for the back new leaf spring from cj some cheap and "stock"
pic of car when i started
little red dots are approximately inch lower
Why do you ask ?
Did i do something wrong ?
Discussion Starter #31
Aaaaand one year is gone. bought stang one year ago.
Looking on other posts and my progress i am not so happy...
I am working alone (beside 4 days with friend), my first full resto on unfamiliar car that have rust problems and other 50 years problems.
Car was running and driving for 200 meters and then I deasembled it..
with first kid and month ago second, time for garage is limited..
I am traying to work every spare minute on car..
for now disesembled , blasted, velded : cowl,front left rail,3 fender apron,2 flor support, left torq box,
rear right frame rail, trunk crossmember.
there is loong way to go...
few pics from start and now..
Very nice! Keep up the good work!
:eek:)
Tony K.
dont be discouraged! You're doing a awesome job!!
think of the pleasure you'll have when you get to drive it =)
BTW, will you keep the inline 6 engine?
Discussion Starter #36
tnx guys.
Yes , I6 going back. will upgrade front disc, 5lug rear, uca drop , some custom welded frame conectors..
But engine stays because this will be wekend cruiser.
With todays big tickets for speeding I must go slow :)
21 - 40 of 63 Posts
