Apply NO HEAT to one of these proportioning valves. Heat will melt the plastic tip pf the piston.Not sure I understand the question,,, If removing break the lines loose, remove them, On top of the welded bracket there is a C clamp, pull out with a small flat screw driver, after you get out, put in a vise, but wrap it with a cloth, the brass will nick up if not, use vise-grip with cloth, you might have to heat with propane torch, it will turn at the split to make [2] parts, clean it up before you start, you will see the split in the brass. You will have to buy a new rebuild kit to get the o rings for the inside, There are videos to show how.
This is true, You will melt the rubber ball and plastic, Heat as a last step,and only at the hex end. I should have stated that, They can be a problem to get inters out, there are other ways.Apply NO HEAT to one of these proportioning valves. Heat will melt the plastic tip pf the piston.
Nice block, great ideal, much better then the vise gripsPretty sure he's just asking for the hard line 90. Pretty much a 'make your own' component. Send me the length of line between the nuts - use a string - and I'll see if I can knock one out for you. And to get the silly cylindrical prop valve apart, I made this block years ago. Put the valve in it, tighten two top bolts, put in vice, celebrate with beverage of choice. Why so many bolts? At first it was still connected at the bottom. Works much better as two halves.
I believe West Coast Cougars sells these at about $65.00Want to sell the old Proportioning valve?
Dan
Yes, pretty easy to make. I think some of the OP's confusion is that although the line is 3/16" there are 2 different sized tube nuts used, like between the M/C and distribution block. One is a standard 3/16" tube nut with 3/8-24 thread and the other, I believe is a 7/16-24 thread.Pretty sure he's just asking for the hard line 90. Pretty much a 'make your own' component. Send me the length of line between the nuts - use a string - and I'll see if I can knock one out for you. And to get the silly cylindrical prop valve apart, I made this block years ago. Put the valve in it, tighten two top bolts, put in vice, celebrate with beverage of choice. Why so many bolts? At first it was still connected at the bottom. Works much better as two halves.
