I attached my parking brake to the firewall of my '67, as per the shop manual. While the figure in the Shop Manual was difficult to see, I installed the bracket (in the pic below) on the firewall, in the engine compartment, attached to the parking brake assembly.
Do I have this bracket installed correctly?
What does this bracket support...speedo cable?
Thanks.
Almost missed this one over here in the general section. ;)
Since this is a manual trans car - its for the return spring that also attaches to the top portion of the equalizer arm. If your restoring it it should be darker in color (looks freshly blasted)
Discussion Starter · #4 ·
I see now...thanks.
I wasn't sure about the finish, because the previous owner had pickled the engine compartment with grey primer. I did not see any paint under the primer, so I blasted and "Oxisolved" it. Do you think a little oil will darken it up enough?
Thanks again.
