I replaced front brake lines and had booster, MC and distribution block professionally rebuilt. I can lock up rear drums but not front disc on an original 1967 GT fast back. So, I am guessing rear proportioning valve needs rebuild/replace as well. I bought Classic Tube set from NPD for the whole car. My questions:
1- I don't see the 3 way brass connector for sale anywhere that you can see in the first 2 pictures and it seems to be part of the rear flex line. I see rear flex line for sale, but not like this.
2- I see NPD and Branda have the proportioning valve, but I can't find the little 2" or 3" hard line that connects the valve to the flex line bracket. My NPD kit didn't include it. Do I make it?
3- I checked out a friend's 1967 coupe with great brakes and the proportioning valve is not where it should be. Maybe moved? I would think it is a necessary part.
The rear brake hose assembly includes the brass block to connect the left and right rear to the main brake line from the engine compartment. The in-line cylinder you picture is a 10 psi check valve that retains 10 lbs of pressure to the brake shoes so the rear brakes engage at the same time as the front discs. When I bought a new proportioning valve, I also got a new one way valve. My brake line kit from classic tube included the small 90 degree brake line connecting the check valve to the hose.
1. It is part of the rear brake hose - BRAKE HOSE, REAR - #2282-2 - National Parts Depot
2. Mine came with a complete brake line kit. It should be available but I'll admit after searching the NPD web site for 10 minutes I came up empty. Are you sure that the classic tube set did not include it? Did you buy a late 67/68 set? Give NPD a call on this one.
3. Was it moved to the front near the distribution block? Regardless you should have yours rebuilt rather than trying to run without it. I have not purchased a reproduction and I always come down on the side of rebuilding rather than buying something new, but that is of course a choice. If you buy new keep the old one if you want to go back to original some day.
Pictures display a stock 67 Disc Brake proportioning valve. These can be rebuilt. Muscle Car Research has the kit to rebuild them. Yes they can be a challenge, BUT can be done.
I'd put your classic back to factory, not swap out misfit parts.
