· Registered
I pulled my strut rods out of the "pulled from the car and might still need" pile
and noticed that one was slightly bent. Then I noticed that one of them has a
tapered end with a hole drilled through for a cotter pin and the other one doesn't.
Which is correct for a '67 'vert?
Rich
'67 C-code 'vert (Dees67)
'69 GT FB (project car)
Check out my band http://www.brickyardblues.com
· Registered
Hi, i'm not sure of this as my coupe had the same thing the drivers side had a cotter pin the passenger side did not John
· Registered
This I heard from a parts guy at Mustangs plus a few years ago. One rod was made in Canada and the other was made in the US. I think the Canadian one had the hole for the cotter pin. IIRC, its the passenger side rod. No, you don't need to use a cotter pin.
Black primer 66 coupe, bench seat, 68 302-2V, C-4, 3.55 TSD
879 posts as "66 bench-coupe" on old VMF
robert94928 on Yahoo Messenger
The rust on strut rod threads on a 67 is unbelievable!!! Who the hell needs cotter pins?
"When you hear pounding hoofbeats, think horses, not zebras." - Dr. Harold Slavkin, Dean USCSD
