I have a 66 mustang that I am swapping a 68 302 into. I bought a pair of GT40 heads, not gt40p, and I was looking to see what all I need to make them fit on my motor that has a .475/.475 cam, flat top pistons, and a weiand stealth intake manifold? I was planning to use JEGS long tube headers 555-300130.
1967 Mustang Convertible
You will need Pedestal mount Rockers, pushrods, and gaskets. Everything else bolts up the same. They come with 64cc chambers so you will lose a little compression but flow better then stock heads, like 351w heads.
Reactions: 2nd 66
You will need pushrods for 78 to mid 80's 302/5.0 with flat tappet cam. You will also need inserts on the end of the head to seal off the Thermactor port. They're cheap. That's about it. You will loose some compression but the added flow should more then offset that.
