1 - 14 of 14 Posts
Hello,
I like to change my 428 FE automatic in to a stick shift car.
Should have the most needed parts here, as
Clutch + Flywheel,
C60A-D Z Bellhousing,
RUG-S 428 (Shelby?) Toploader (10/31 spline) without slip yoke
Shifter,
Pedal Assy.
Now wondering, will be the drive shaft usable from C6 -> Toploader?
is the slip yoke usable?
It looks, like toploader plus bell housing is rough 3" shorter than my C6?
Thank you !
Joe
Slip yoke is the same (both 31 spline) but the 4 speed d/s is longer as you suspected. I can get you the exact dimension from the Ford Master Parts catalog or you can find it on the internet. 428 Cobra jet.org is a great source for everything CJ related.
Randy
Reactions: GTFastbacker
Also, the trans crossmember is unquiet to an FE setup.
C7ZZ-6A023-A.
Think the number "250" is on mine
Trans ID tag for a '68 428 stang is RUG-AE
My 390 is RUG-M1
Your C60A-D Z Bellhousing is listed for a '68 390GT = C6OA-6394-D. Guess would work.
They list for a 428 CJ C8OA-6394-A
Of course you need diff radiator, backup switch.
driveshaft, for 1968 = 428 CJ manual 50" long, C8zz-4602-B. for an auto = 46 37/64" long
For a 390, 50 1/64" manual C7ZZ-4602-C, for auto 46 37/64" long
Randy
I got a list yesterday shows all these different lengths of drive shafts. thank you for advice !
C7ZZ-6A023-A.
My 390 is RUG-M1
Found a crossmember on my pile. Why another radiator? can I block the transmission cooler fittings?
Mustangtek reads RUG-S for 428 / Shelby ?
maybe later I will upgrade. for now I like to stay "factory like ;-)" Thank you for the link, I dot knowed this company before.
There are a number of small specialized companies that are favorites of VMF people. OpenTracker is one plus Street or Track & Chongostang - all three will gladly talk to you on the phone and give you honest advice. And look at the others at "Vendors" under "Forums" at this site. For big block Mustang parts, also check out Welcome to Mansfield Restoration Parts
Keep us informed. And we love photos.
PS I love the TKO600 behind my 390. The overdrive makes a world of difference on the highway.
Here's a couple id charts, first for All Fords, 2nd one just mustang on manual trans id's.
I don't see any RUG-S...
Discussion Starter #12
to be honest, this time its not about my Fastback, here i convert my 427 Cougar GT-E in to a stick shift car.
Since its a litte bit of blasphemie i can not ask the cougar guys for advice, the most of them see the car ONLY in factory like concours nuts and bot correct.
I do the same, with a little bit of creativity. I use ONLY original parts from 68, and the Parts Ford had used if they had build stick shift GT-Es.
But they dont, all build 427 cars are automatics. I use 68 428 CJ parts as Bellhousing, Transmission and when i can locate a 428 drive shaft.
I find these dimensions really odd given how sloppily these cars were made originally, plus the play provided by the slip yoke. Lengths to 1/64"? Seriously?!
The yoke from your auto should work. Get in the phone book or call your local speed shop and find a drive shaft company, for about a boat buck ($100) you can have your shaft modified to any length including balancing. They will tell you exactly how to measure for the process. Easy as pie...
1 - 14 of 14 Posts
