I'm not sure of the vacuum hose routing for this distributor.
The hose from the vacuum tree at the rear of the intake conects to the thermo switch on the thermostat housing - does it plug into the upper or lower conection point?
The hose from the carb's timing vacuum port will connect to one of the distributor ports, the other will be from the thermo switch. Which one goes where?
Thanks.
