1 - 9 of 9 Posts
Hi all , a quick question hopefully somebody can help , I have a 68 with a 289 , the distributor I think was original , I brought an HEI replacement online not knowing that there might be a difference of long shaft , mine appears to need a short shaft one , is there a difference, the oil pump shaft seems to be 8 mm on the new one whereas the old one is 6mm , has anyone had a similar issue ?
Help please lol 馃槀
Thank you
1966 GT 4spd
I think what most are going to tell you is to return the HEI unit. There are units that are genuine Ford pieces that will work the same if not better and not look hideous on your engine(IMO).
Why are you replacing your distributor to begin with?
Welcome to the forum!!
Chris
68 Mustang Coupe
Help please lol 馃槀
Thank you
Sounds like you've got a 351w distributor. It should be the same length from the mounting surface down, but the oil pump drive shaft is 5/16" aka 8mm vs the 289/302 ones at 1/4" aka 6mm.
The HEI type distributor would be my last choice. A properly tuned stock distributor can easily equal or surpass the performance of the HEI. Any OTC HEI would have questionable advance curves, at best. I have never seen a distributor come out of the box properly adjusted.
Being in Britain, V8 Simon needs a one-and-done solution. Obviously, shipping the existing distributor to the US for rebuild and adjustment is an expensive proposition. Probably best to have someplace like the Mustang Barn set up a remanufactured distributor to fit the configuration of the car and ship it.
Yeah, sounds like you got a 351W distributor and not a 289/302 distributor. I don't know what, if anything, is available Across the Pond. I would suggest looking for a factory replacement distributor and, if possible, someone local who can calibrate it.
1966 GT 4spd
Well its been 2 days, not sure if they will be back?
Chris
Reactions: Redneckgearhead
1 - 9 of 9 Posts
