I just bought a 68 coup with manual drum brakes all the way around. I have some left over parts from my 65 , factory dual piston calibers and the rotors. I want to convert the 68 to front discs, will the 65 stuff fit?? If so, what else would I need?? Spindles, master cylinder??? Thanks
763202
The caliper brackets from the 65 should work on the stock spindles. Maybe a new master cylinder and proportional valve.
65 disc brakes are 4 piston Kelsey-Hayes calipers. If this is what you have with the spindle brackets, they will bolt onto the 68 V8 drum spindles.
Add a dual bowl master cylinder for disc/drum and you're set.
Sent from my SM-N960U using Tapatalk
