1 - 2 of 2 Posts
hi, anyone know the correct ford part number for this dipstick? I change oil and filter and reads max full with only 4 quarts after use. Mine is c9oe 6750 b
Attached is from the 1965-72 Ford Master Parts Catalog. Note that it shows the Part Number and dimensions of the correct Dipstick.
Also note that the number you gave (which I assume you read off of the Dipstick itself), is not the Part Number, but the Engin
eering/ Identification Number. While these are usually similar, they are not identical. Yours may be correct. You need to compare the dimensions shown in the listing with yours to be sure.
Hope this helps.
Bob
1 - 2 of 2 Posts
