So the 8 track doesn't work that I got with the 69 I bought. The belt was gone so I cheaply put on a o'ring. Finally bought a few 8 track tapes (Fleetwood Mac and some Willy), put it in, nothing...
I open the 8 track back up and find that the motor (with the belt/o'ring removed) will turn a revolution up to about 3 when it's first turned on, but that's it. It spins freely by fingertip and you feel a bit of a vibration with the power on when holding the belt pulley. Any suggestion as to why this is happening? The motor? The capacitor?
I know about starting and running capacitors so maybe this one needs that as well and that's the problem? With my volt meter across the motor feeds I get a surge when the power is first turned on (not long enough to get a reading), then back to just millivolts.
I posted a picture of the circuit board with the capacitor, diodes, resistors and transistors...
As a side note, I can turn the big pulley and get sound so the motor issue is the last thing that needs fixed.
Allen
Allen
