I have a 1969 Mach 1 build I finished earlier this year. Although I rarely drive it at night, I recently had to use the headlights and found they don't work! They used to work. When I completed the build the headlights worked though on it's maiden voyage, the lights did go out and come back on a couple of times. In fact, they did the same thing when I was later adjusting their aim. However, they subsequently worked ok, though a short drive. Now the headlights seem completely dead. However, the rest of the lights still work...tailights, side marker lights but headlights (low or high) don't work, nor do the front turn signals which in my 1969 3-wire configuration I believe they also operate as parking lights. From what I've read, the normal culprit given these conditions is the headlight switch (and the high beam indicator quit working too). I tried to debug it tonight but I don't have a good sample to compare or a diagram to determine how to benchtest a switch. The following is what I found:
- This is a replacement repro switch, so it is clean but not a Ford part.
- I found the switch had the following terminals: B, A, R, I, P, H, D1, D2
- With the ignition switch off, I found 12V at B, D1, and D2
- With the switch powered and pulled out to the "headlights on" position, I found the rheostat got very hot to the touch quickly
- After pulling the switch, I found:
o headlights off: there is continuity between B and A, as well as, R and I
o parking lights on: there is continuity between B and A, B and P, and B and I
o headlights on: there is continuity between B and A, B and H, and B and I
I assume I need a new switch but would be interested in any feedback you might have. Thanks in advance!
