1 - 9 of 9 Posts
Does anyone have a template for the holes of the stock AC vents in the lower dash on a 69? I am have a non-AC car and I’m about to install AC. I have a set of side vents and was hoping to avoid having to buy a lower dash just for the vent holes if I can cut them myself in the one I have. Thanks!
It is NOT just a set of holes. They are stamped and formed to fit the original bezels. I can get a close up picture of the holes tomorrow.
If it was just cutting holes, then the AC dashes would not bring $500+
Maybe I’m mistaken, but from pictures I’ve seen, there are two large holes in the lower metal dash with a notches on the top and bottom. They don’t seem to be indented, but maybe I haven’t had a good angle. I have everything that would attach to the vent hole in this picture, like the bezels, louvers, etc that you mentioned.
801746
69 Sportsroof
If you are getting a Classic Auto Air System they supply you with the vents and the templates to cut holes for their vents but they are not factory size.
Discussion Starter · #5 ·
Going with Vintage air but same deal. The vent holes from vintage air seem to be smaller than the factory ones. I could use the vintage air template to get it close, then just make them a little bigger to work with the factory vents, but wanted to see if someone had tried this before and had a template they made. I thought I saw on here a while back someone had done so, but no template posted.
Someone on 69stang.com posted a layout of the vent holes. The holes in mine are nothing special.
Wood Window Fixture Gas Tints and shades
Automotive tire Motor vehicle Wood Gas Automotive exterior
I have seen templates for a DIY installation of the stock vent assemblies in '69 and '70 Musangs. I can't remember where I found them but it should be searchable on the internet. I don't have time to search right now.
Found it:
Reactions: Grabber70Mach
Discussion Starter · #9 ·
Found it:
I saw this as well on eBay, but I wasn’t sure if anyone else has tried to it out? Didn’t recognize the seller. I found the post on 1969stang, but the link to the PDFs are broken. I’ll try to see if I can get them though.
1 - 9 of 9 Posts
