Vehicle Teardown:
After a few months of hesitancy, I finally started teardown. My goal was to remove every part from the body as I knew some extensive metal work would be needed. I documented every part by snapping a picture, noting how it was fastened, how many fasteners it used, what they were, where they were, and how the part came out. I then tagged all fasteners with small part baggies and the actual part with tape or a gallon bag, depending on size of course. This was then all tracked in the journal along with notes after each day of work to learn from later. Again, it may seem like overkill, but it has come in clutch more that I thought already, and I’m still working on metal! Most aspects of the teardown were what I would assume to be pretty standard, below I’ll share some highlights and finds along the way.
I waited a bit to tear into the engine, but between some bad pitting in some bores and a few bent rods, I’m not sure the fate of the engine, but it seemed bleak. (worst bend pictured, others were bent out of straight, but not by a lot).
Just about anytime I banged on the car or used an impact, rust fell off, this was a fairly common find after a few hours under the car, that’s when I started to realize how bad it was.
Did I have to spend multiple days getting the right tools and patience to cut out the leaf springs? Yes…
I was proud of this one, I wanted to store the front and rear glass in something rigid enough to carry, so I used some old PVC laying around to make a carrier with a center divider. Once the windows were out, I wrapped them in some cheap HF moving blankets and cardboard. So far they have survived a few trips in the house, down stairs, and now through a move to another state, so I’d say it’s worked!
A common theme that carried through this teardown was eviction… I found numerous mice nests/homes/metropolises. The first came in the heater box.
The second and third came from the headliner. I kept just about all things from tear down, the headliner, went right into the trash.
As I mentioned, the interior was painted black over red. I’ve kept the pieces, but I’m not sure if I’ll reuse them or not. Thankfully, I have a lot of time to decide on that.
