1 - 13 of 13 Posts
1969 Mustang Mach 1
Ford 999 report original equipment:
Built in San Jose (registered in Los Angeles and San Diego since new)
351 Windsor
FMX automatic
3.25:1 open differential
Power steering
Power drum brakes
Sportdeck rear seat
Indian fire red paint
AM radio
This car was fully media blasted and has had a full rotisserie restoration. Every wear item is brand new, every original item fully reconditioned. There are many posts on this forum documenting this build...
Rebuilt original parts:
Fully rebuilt steering box
Fully rebuilt power steering pump
Flawless and fully functional rimblow steering wheel
Seats reupholstered in genuine NOS comfort-weave (Note: comfort weave reflects camera flashes due to its woven nature and does not appear true black in photos taken with flash… it really is black)
Teak interior, not the more common walnut.
All new genuine Moog suspension and steering components
New brakes and rotors/drums
All new AMK hardware
All new hoses
All new springs and shocks
Original black plates with 1969 registration sticker; YOM ear tags for valid registration.
This car has been modified; however it could easily be reverted to stock other than the color change.
Car has been garaged and has less than 2000 miles since total rebuild.
Modifications:
Painted Ford torch red with Glasurit paint
Flawless show quality paint finish; fully color sanded with no orange peel.
Rear wing added.
Converted to front wheel disc brakes/spindles using factory donors from a 69 Mustang
Converted to manual brakes using Maverick master cylinder
Converted to a 1994 roller cam 351 Windsor block
Forged internals, 10.5:1 compression, 393 stroker crank/rods
AFR 185 heads
JBA ceramic headers
Edelbrock manifold, carburetor, and rolling thunder cam.
Magnaflow stainless steel exhaust with quad tips
Genuine OEM dual exhaust rear valence.
Custom AOD 4-speed automatic transmission with wide ratio gear set
Edge 3500 stall speed torque converter
Currie 3.7:1 torque sensing differential (final drive in 1st is 10:1)
Total Control Products subframe connectors
Custom wheels
Antenna delete (original antenna included)
Modern radio with reproduction bezel (original AM radio and bezel included)
Lower dash is from an AC car. Speakers hidden in AC bullets.
Stainless steel doorsills
Items to address:
It is running rich and would benefit from a dyno tune/re-jet
There is a leak from the transmission cooling line fittings (I have lost access to my garage with lift to address this)
The chrome trim around the clock needs to be refurbished.
I travel a lot so responses may be delayed. Thank you for looking!
Discussion Starter #2
Price adjustment: $39500
1969 Mustang Mach 1
351 Windsor
FMX automatic
Power steering
Power drum brakes
Sportdeck rear seat
AM radio
All new hoses
Modifications:
Rear wing added.
AFR 185 heads
JBA ceramic headers
Custom wheels
Items to address:
Price correction: $37,500
It seems I have no idea of the car's value... Input welcome.
this still available? if so im interested. please call me at 248 842 7541
Question: Does Ford even do/offer those classic "999" Reports anymore?!???? I remember that they were always a cute addition to any car's Original Paperwork...
I remember that you would dial a 1-800 number give your car's info and about 4-6 weeks later a "999" Report would show up in the snail mail home mailbox.
Has anyone done one in recent years?? Are they even available any more?!?
Related:
https://www.talladegaspoilerregistry.com/2015/06/08/ford-takes-on-marti-reports-part-2/
$17 for Basic 999 "Build Sheet" and $46 for a Deluxe 999 "Build Sheet".
See an example of one below:
Obviously, A Kevin "Marti" Report is a Much Better investment...
:eek:)
Tony K.
I've followed this thread since day 1. Did it ever sell?
1 - 13 of 13 Posts
