1 - 9 of 9 Posts
I'm trying to find out what size rim and tire to put on my '69 mach 1. It currently has the proper stock on it and I'm wanting to put Magnum 500s, but am uncertain of the size on the rims and tires to have the proper spacing. The suspension on the car is standard. Any help on this would be appreciated. Also, did the mach 1 have a tilt steering column option in 1969? Thanks.
On the Magnums, you can go 14x7 or 15x7 (originally available on the Bosses) easily. Probably more about tires available (or desired) than particulars, both will fit.
'69's had "tilt-away" as an option, it was cvacuum actuated, and pulled the wheel out of the way for exiting the car. '70s, with a completely different steering column, could be had with a more conventional tilt column.
Carl
One of my 69's has the 14 in magnums and the other has 15 inch aftermarket mags both according to the Marti reports came out with 14's according to 69 brochure they came out with E70-14's or F70-14 wideoval tires so looks like a 14 inch rim but 15's sure look nice
Don
Try Him
Ask this guy. He's THE expert.
True Design Wheel; Magnum 500
15x7's are a good way to go. If you want big fat tires on the back then 15x8's on the back and 15x7's on the front would be better. Going 15" vs. 14" opens up a world of tire possibilities that are available that aren't available in 14". There is little difference in appearance between the two.
I won a special award
I have 15x7 Magnums on the front and 15x8's on the rear. The fronts have a backspace of 4.25" (stock factory backspace) and the rears are 4.5". My wheels are from Specialty Wheel of Oregon.
69 mach 1
Thanks for the replies. 6t9mach1... what tire/rim combo do you have on your black mach1? Looks great! Maxum96... do you have 15x8s on the back and did you lower the suspention at all? A great car too! From what I've found, it looks like 15x7 with 225 60s in the front and 15x8 with 275 50s in the back will work nicely. Agree, or too big of a tire in the back??
225/60's are good for front but I'd go 275/60's not 50's on the back to fill the gap between the quarter and tire.
I agree.
1 - 9 of 9 Posts
