1 - 11 of 11 Posts
Battery new ,solenoid new,battery cables new , no lights no crank no starter motor click ,fuseable link ok
Got a test light? Hook the alligator clip to a ground on the engine, like a carburetor stud. Probe the large lug on the front side of the solenoid where the positive battery cable attaches. There should be power. If not, inspect the connections at the battery and the ground cable connection at the engine block. Battery cable ends should be clean and shiny. If you have power at the solenoid, check to make sure that all the FEED wires to the interior are connected at the large lug on the front side of the solenoid as well. This lug is used as a "distribution block" for all the power feeds for the car. I'm guessing something isn't hooked up correctly.
Do the headlights work? If they do and it just doesn't start then check your Neutral Safety Switch if it's an automatic.
Make sure you didn't lose the main power source wire that goes on the solenoid where the battery cable connects. Otherwise, you need a test light or ohm meter and start chasing power from the positive terminal downstream. Check your ground circuit also. Its quite possible you end up at the ignition switch which does go out. SOmetimes the bulkhead connector gets funky and needs to be disconnected adn the terminals cleaned...
An automatic trans in park? Check power to the back of the switch? Check the fuses? Double check battery with test light?
Use a pair of pliers or screwdriver to jump your solenoid from the left large post to the left small post. Make sure you’re insulated or you’ll get a shock.
Is it an auto or manual tranny?
Automatic tranny could be Neutral Safety Switch issue as mentioned above. Said issue however might not be the switch, but the linkage which tells the switch if the car is in P or N. If the linkage is off you won't get power to the starter.
If the car was auto and converted to manual, you need to jump the NSS wiring.
What was done to the car before the "no start"? Was it running or had it been sitting for a few years? A little more background on the car and issue would help a lot in giving possible options.
1 - 11 of 11 Posts
