I am installing the fastback side scoops on my 69 clone. I have inner and outer repo scoops and ducting w/hoses. The scoop install kit (Branda) came with the metal brackets seen in the photo. Can anyone tell me how these attach to the scoop and what if anything secures the outer scoop in the rear to the quarter panel?
Thanks for any help ....
Dave http://spectrum-photo.com/scoop.jpg
If I'm not mistaken, the little metal clip gets screwed/riveted to the car and the rear bracket slips underneath it. The front of the scoop is then srewed to the car to hold it in place. You have to make sure that the clip is located correctly to hold the scoop where you want it.
The earlier post has it right. That's how mine are installed. The strap on the scoop goes behind the leg of the z bracket. You'll have to position the bracket by measuring from the screw holes on the front of the scoop to the strap.
