I guess being a dynacorn shell, what frame mounts are you using? Big block or small block motor? Kinda looks like an FMX trans?
Hard to tell from the pics. Are the studs for the trans mount too far back or forward for the holes?
I won a special award
if the transmission is a fmx trans would the crossmember be the same
No. FMX uses a different crossmember than the C4. It looks like this,
Crossmember should go on either way and holes are to one side so did you try turning it around?
